1999 Outback Ignition Switch
3182 4
Car; 1999 Outback 2.5l Manual Trans
Just purchased my first outback a week ago for a relatively awesome deal. One quirk the car has is it won't turn over unless I wiggle the key in the ignition. Went ahead and replaced the starter and double checked all connections to starter/battery because it was warrantied and the issue persists. Battery is new.
All research for these symptoms points towards ignition switch or lose ignition related wiring.
Is this a fixable issue? What parts do I need to replace and how difficult/expensive is the task? Would it be worth it to just take it in and have it done?
Also, on a completely unrelated note, when I was replacing my starter and had the airbox off, I noticed this harness just hanging out. Brand new to this car so I'm not sure what it's purpose is. Pic here: http://i.imgur.com/0tviqT6.jpg
All help/information is greatly appreciated !
The harness you posted the picture of id for the Optional Heated front glass, the rubber plug above it is the access to the glass area. On the ignition issue I would do or have done a voltage drop test on the ignition circuit, you should be able to replace the ignition switch electrical without too much trouble.
Sorry to bump this old thread, but I did want to answer my own initial questions for anyone who's searching around for information.
The problem I was experiencing was having a very worn key, and my spare keys were made from my worn key. I had a new key cut off the vin at the dealership and I have no more problems. For anyone who's having similar problems this would be the first thing I would test if you have a seemingly worn key.
Thank you guys for giving me information last Feb! Will be more active here.
I has car.
It would have been handy to mention that when you inserted the key in the ignition, it didn't turn at all until you wiggled it.
That would have ruled out a starter issue right off the bat.
