1999 Outback with 310,000 miles. Pass or buy?
508 4
Talked the guy down to $500, he says it runs well, it just has a lot of miles. Water pump, timing belt and front suspension replaced recently. Its a manual, doesn't look like it has rust. Should I be scared to buy an outback with that many miles on it?
got a link? post it up.
I own 4 Subarus. A 95,97,02 and a 14. The first two are 2.2 and the last two 2.5.
Overall, for $500 it only has to run for 5K miles and you have your money back. So there is only a little risk. If it was an auto, I would say OK for sure. This assumes that the car is running fine. The clutch will fail on a manual subaru, but likely this one has already been replaced.
personal choice.
why are they selling? there's usually a precipitating reason...find out what it is. if it's clutch related or engine related try to find out.
how good are you at assessing a vehicle?
if you get rosey colored goggles over cheap cars then your discretion might be skewed.
tons of miles but the comment above about it only needing to last a little while to be worth it holds.
if it's been well maintained 310,000 isn't necessarily scary. although i don't really like buying a manual trans with that many miles the chances of throw out bearing, input shaft bearing, clutch, pressure plate, synchro issues, torque bind aren't negligible.
