How much do you think it will cost to do timing and a water pump on a 1999 Subaru Outback Limited... DOHC 2.5
Price and Labor included
2010 OBW limited 2.5 CVT
If you do it yourself, about $250 for parts (Ebay is your friend). Around here, a timing belt job will run about $800-1000 depending on what all you have done with it. Ask what the shop rate is and how many hours to do the total job. the labor is the biggest part of the job.
Meh.
I has wagons.
For a proper TB job:
belt
ALL tensioners/pulleys
water pump
crank seal
cam seal
reseal oil pump
At a mechanic they'll run $800 to $1200 depending on your area.
