I'm opening a new thread to get better attention and hopefully someone can help me.
I had problems installing my 19mm RSB and stipped out one of the bolts that hold the bar up. I setup a new bolt and nut with a locking washer and tightened it up real tight. I looked under tonight to make sure everything was holding and I noticed that the bar had slid to the right and the metal circle ring that are on the RSB itself had slid next to the bushing on the right hand side. Now my problem bolt was actually on the left hand side. I loosened up the bolts and slid it back so the gap on each side was even and went for a ride. Well when I came back it had slid to the right again.
When I grabbed the bar and pulled as hard as I could I got it to slide back to the left but it took a lot of force. I know my strength is not anything near what the car puts on it but the brackets on the right side at the very least are tight and holding just fine. So at this point I'm inclined to think that if the bar wants to go right it could go left if needed to?
One thing I noticed when installing the RSB was that the bushing's were covered in this waxy substance. I got most of it off as it wasn't on the stock bushings so maybe thats the problem?
Anyway looking for some friendly guidance.....I need a beer.
