Copy and pasting the data was quicker for me than opening a host account for the file. I plan to do 6 total analysis' on my subie and I'll set up a host at that time, totally unnecessary but I'm a numbers kind of guy. I'll keep all updates here till I do the final 6 then repost if it makes sense. Went through Blackstone because they make it easy with the packages they set up for you.
First number is my engine / second number is universal average for this engine with 4600 miles. This test the oil had 3871 miles on it, still factory stuff. About 90% of that driving was all 60-70mph highway driving. My schedule at work has changed and I'm now driving 75% stop and go and 25% highway speeds. I plan to keep the oil till 7500 miles at this point but if the color degrades too much I might change sooner. I'm close to 5k miles today.
Subaru 2.5L 4-CylMAKE/MODEL: OIL TYPE & GRADE: Subaru 5W/30
UNIGasoline (Unleaded)FUEL TYPE: OIL USE INTERVAL: 3,871 Miles
COMMENTS
DAVID: Don't be alarmed by the high wear and silicon. The metals are from new parts wearing in and silicon is from sealants and sand-casted parts. Both are perfectly normal in new engines like this one.
Universal averages show typical wear levels for this type of engine after about 4,600 miles on the oil. This engine should look that good after a couple of oil changes. The viscosity was mildly thin for 5W/30, but that's harmless. The TBN was strong at 3.3 showing lots of active additive; less than 1.0 is low. We'd change this oil when it's got 5,000 miles on it.
ELEMENTS IN PARTS PER MILLION MI/HR on Oil 3,871
UNIVERSAL AVERAGES MI/HR on Unit 3,871 UNIT /
Sample Date 05/20/12
Make Up Oil Added 0 qts
ALUMINUM 6 / 3
CHROMIUM 0 / 1
IRON 18 / 8
COPPER 18 / 4
LEAD 1 / 3
TIN 0 / 1
MOLYBDENUM 109 / 71
NICKEL 0 / 0
MANGANESE 3 / 3
SILVER 0 / 0
TITANIUM 0 / 0
POTASSIUM 6 / 2
BORON 155 / 49
SILICON 97 / 12
SODIUM 6 / 35
CALCIUM 2067 / 2212
MAGNESIUM 11 / 129
PHOSPHORUS 720 / 713
ZINC 800 / 852
BARIUM 10 / 0
PROPERTIES
SUS Viscosity @ 210°F 54.6 / 55-63
cSt Viscosity @ 100°C 8.66 / 8.8-11.3
Flashpoint in °F 410 / >365
Fuel % <0.5 / <2.0
Antifreeze % 0.0 / 0.0
Water % 0.0 / <0.1
Insolubles % 0.2 / <0.6
TBN 3.3 / >1.0
* THIS COLUMN APPLIES ONLY TO THE CURRENT SAMPLE
416 E. PETTIT AVE. FORT WAYNE, IN 46806 (260) 744-2380 Blackstone Labs
©COPYRIGHT BLACKSTONE LABORATORIES 2012 LIABILITY LIMITED TO COST OF ANALYSIS
COMMENTS
ALUMINUM 6 / 3
CHROMIUM 0 / 1
IRON 18 / 8
COPPER 18 / 4
LEAD 1 / 3
TIN 0 / 1
MOLYBDENUM 109 / 71
NICKEL 0 / 0
MANGANESE 3 / 3
SILVER 0 / 0
TITANIUM 0 / 0
POTASSIUM 6 / 2
BORON 155 / 49
SILICON 97 / 12
SODIUM 6 / 35
CALCIUM 2067 / 2212
MAGNESIUM 11 / 129
ZINC 800 / 852
BARIUM 10 / 0
PROPERTIES
Fuel % <0.5 / <2.0
Water % 0.0 / <0.1
TBN 3.3 / >1.0
