'99 OUTBACK AT Green
When I was out on a offroad trip the other week We went down onto tjhe beech(had a mad time) but when coming out up a quite steep boggy, sandy hill auto selected to 1 power button selected foot down I noticed that the engine revs atrted to drop off as the wheels were spinning
I think that the AWD sensing may have reduced the enigne revs to compensate for slippage
I believe that the OB usually runs as front wheel drive and AWD system selects rear wheel if there is any slip
As forward momentum is a prority when in soft sand this causes a problem
Can you bypass these sensors?
I know that there is a company that provides bypass switch to lock in the rear wheels permantly, but havnt discussed this with them yet
ANY IDEAS?
Tokyo's between my toes
2001 Wintergreen Outback 5MT
I've never had problems on sand with mine (98 5MT) but then, I haven't tried to climb a sandy hill.
MY17 Subaru Outback 3.6R
Aren't all newer Subarus AWD....As per my siggi
2001 Outback 2.5l Auto white on silver
Pretty sure that's right chrisx. Not sure about power transfer in the situation described in the first post though???
Over Christmas I took our Outback (2.5l Auto) up a reasonably sand hill without any problems at all. (Not a sand dune/beach scenario though.) In fact I did it a few times as it was so much fun! Tried it in reverse too, which was not such a good idea!
That's true, but to different degrees depending on the transmission & engine type. For Outbacks (non turbo) 4cyl MT are 50:50 (F:R) always, 4cyl Auto 90:10 normally.
Really, I wasn't aware of that. :rolleyes: That certainly explains a few on road wet weather handling characteristics then. ;)
