Leak in cooling system is significant enough to prevent vacuum and cap from using the reservoir tank, it causes overheating after enough fluid leaks out and for some reason water doesn't seem to go through heater coil no matter how much fluid is in the system. Upon inspection fluid pools on top of the engine block near the water pump. Any possible diagnoses would be appreciated.
