2000 Legacy GT engine swap
4312 Views 5 Replies 2 Participants Last post by  eagleeye
Okay so I have a 2000 Legacy GT 2.5, manual transmission with a seized engine. At my shop I have a 2002 Outback 2.5 with an automatic transmission. The Outback engine is verified good, tested, so I decided to do an engine swap. Everything looks almost identical other than the map sensor placement on the intake manifold I don't really see very many differences. Performed the Swap, and now I have a no start. It is getting spark, and fuel, I'm just wondering if there's some possible pick up on a sprocket maybe that isn't allowing it to fire at the correct time? I'll try to include pictures and if there is anybody else done the same or close to the same Swap, and there's something I need to replace or overlooked, I would appreciate any input. The donor engine from the 02 Outback was left as it was,dropped in without switching the intake manifold, or any sensors. The only modification that was done was to pull the flexplate off insert the flywheel and the clutch.
Engine on the left is the siezed 2000 legacy GT, engine on the right is the one going into the Legacy GT, from a 2002 Subaru Outback 2.5.
take the timing belt and its pulleys/ tensioner/ idlers off the old engine and put them on the donor. (whey you put them side by side you will see the differences).
manual = one type,
automatic = another .
and we have lots of threads referencing the differences in the 2000-2002
EJ251 automatic, and EJ252 manual
here is just one relevant post,...discussing the cams etc:
http://www.subaruoutback.org/forums/110-gen-2-2000-2004/129393-251-vs-252-a.html#post1395329
______
these diffreneces remained in the 2003-2004. only both auto and manual were called EJ251, (with EGR in those years). along side the weirdo cal spec Ej259 of 2004
Wow it never even occurred to me that there would be a difference in the timing components,but it does seem to make sense. I feel like a rookie lol. Well,next time I shall do my homework properly. I was about to go into diagnostic mode. Scope everything. Glad I decided to ask the right people. Now I'm properly schooled in 251 and 252 hehe. Thanks again man.
I meant to type of the cams in my first post. brain just melting there. in the end it will be a good swap for you though.
