2000 Outback 2.5L
I've got a 2000 Outback, the body is in pretty good shape, save for the forward crossmember, which is rusted to the point of needing replacement.
I've got a replacement from the local salvage yard without too much trouble, but after getting it home, I see it's from a Forrester.
Will this be a problem, or is this a common component between the two models?
2003 OBW 2.5L 4EAT
Actually the Forester is an Impreza platform, so I would assume it is somewhat different. I don't know if the crossmember will work or not though.
2002 outback
go here, look at #6. depending on the year, there are 3 different part numbers. NONE show to fit forester. legacy, outback, and baja only.
http://opposedforces.com/parts/legacy/us_b12/type_21/suspension_and_axle/front_suspension/illustration_1/
if you go here, and put in the part numbers, it will show you all the other models they fit:
Auto Parts - Parts.com, For Every Part of Your Life
tomorrow i am going to pick up 2 knuckles from an 01. car has a bad transmission, 130k. i will ask about the xmbr. guy says he also sells a lot on ebay, and it is not really that big. dunno how heavy. car is in ft worth, texas. not much rust here
update:
i picked up my knuckles and fuel pump today. the guy wants 100 bucks, plus 100 bucks to ship. kinda steep, imho. but a real pita to remove. the engine is out of the car, so not much problem. here is his ad: http://dallas.craigslist.org/ftw/pts/3697789726.html
