[2001] Crossgolf's build thread
9251 Views 25 Replies 5 Participants Last post by  Crossgolf
Year: 2001
Engine: H6 209 PS
Transmission: AT
about 135.000 miles
Here are some pictures:
Photo Album - Imgur
This is what I did so far and what I plan to do:
Oil Change [done 1x]
AT Oil Change [done 1x]
Radio upgrade [50% done] Link: imgur: the simple image sharer
Subwoofer [done] Link: Pioneer TS-WX50A Reserverad Aktiv Subwoofer - Imgur
Taillight Light pattern change to USDM [done]
Second rear fog light [bought parts already]
Polishing headlights [no parts yet]
HID-Kit upgrade/retrofit [no parts yet]
21 - 26 of 26 Posts
I used Morimoto ballasts from TRS. An old version that I bought in 2011. The old versions are too big to go inside.
I tried to fit smaller Chinese ballasts in there like you did but I was worried that they could interfere with the electric height control. So I used the stock mounts underneath the headlights. This is one reason why I used the EU/JDM back housings.
With the ballasts mounted there I can still take out the headlight without taking anything else off the car.
The relay is for a later project. It cuts off the high beam shutter from the halogen high beam whenever the low beam is off. I did this because I would like to add DRL to the high beam bulb with a PWM.
The wiring outside of the headlight is totally stock. All the plugs are stock as well so it only takes minutes to take the headlights out. I am not too worried about the stock harness because this car had HID low beams in Japan and I assume the wiring is the same.
First I thought that the black lens holder looks cheap but when I saw it in the headlight with the black bezel surrounding it I thought it matches quite well.
Regarding the trunk lights:
Sorry I don't have a part number. I took three identical lights from three Volkswagen Golf MKIII that I found at the salvage yard. . BMW uses similar lights that are just a little bit longer. Actually almost everything works. There is quite a bit space behind the carpet in all three spots.
I tapped the wiring into the original trunk light in the headliner. I didn't really look for another power source but all the fairing came off really easy. This project took less than two hours over all.
The trunk light has two wires and one ground. So it is best to get the power directly at the bulb because than all the other lights switch at the same time.
[Door/On/Off]-Settings work on all lights simutaneously. Unfortunetly I did not take any pictures of it but it is really easy to set it up.
I just realized that the older pictures are not visible anymore.
Trunk lights:
Trunk and interiour lights in the Outback - Imgur
Bi-Xenon Upgrade
Bi-Xenon upgrade - Imgur
Radio upgrade:
2000 Subaru Outback Audio upgrades - Imgur
Trunk lights:
Bi-Xenon Upgrade
Radio upgrade:
So what size of LED panel did you get to fit in the stock housings? I looked at those things on eBay, but wasn't sure what I could get to fit in the car.
I used your trunk light idea on a project I'm working on. :thumbs-up:
They are 48x40mm and I used two of them in the front light and one in the original trunk light.
Wholesale Product Snapshot Product name is 2pcs 48 SMD Warm White Light Panel T10 BA9S Festoon Dome 48 LED Interior Bulb 12V
I didn't do the map lights in the very front because it would haven been way too bright.
You were able to fit two in the front one? I just measured the back one and the size I found to work (on ebay) would be a 38x38mm. I haven't measured the front yet.
Yes, that wasn't a problem. The lights still work great and light up the car and trunk really really nice. A must have on any new vehicle for me now.
21 - 26 of 26 Posts
