I've been busy tracking down a few oil leaks on my H6. So far I have changed the Valve Cover Gaskets and that helped a lot. Now it seems that I also have a leak coming from the oil cooler. I found a line of oil along the bottom of the cooler, but I wasn't sure if it was from the filter or the cooler. I tied a rubber band to the cooler to act as a dam and this showed that the oil was coming from the cooler/block and not from the filter. I had a look and couldn't see how to remove the cooler. Is there a hidden bolt? Also, would it be possible to change the gasket without removing the coolant lines?
