2001 Outback Limited - H4 2.5
So my oil pan is rusted through, and is leaking oil. Not very much very quickly, but it's still something I want to address. Other than doing an oil change, is there anything else I should swap out while I'm doing the pan? Also, with just over 300k miles, should I use any specific kind of oil, or will any high mileage oil suffice?
Thanks,
-Charlie
01 Outback LL Bean
I would clean the suction tube for debris and buildup and replace the Oring between it and crankcase. This will ensure that the system is not sucking in too much air.
good idea
inspect the tube closely for cracks too. Up at the top where it might be brazed together. Some newer imprezas havd shown cracks there - but yours may be an older design.
is there an o-ring for the dipstick tube too?
'00 Subaru BH 4AT, '06 Volvo P1 6MT, '14 Ford C1 5MT
The two dipstick O-rings are normally fine.
As far as oil... if you find that you are consuming a bit, at 300k miles you are plenty safe to move up to a heavier hot weight (10W-40 in a mild climate, 5W-40 in places where it gets cold). High mileage oil is a ripoff... some of them may have some seal conditioners added, but the vast majority have nothing but a different label on the bottle.
I'm personally running Shell Rotella T6 5W-40 synthetic in mine with stellar results.
