2001 Subaru Legacy Outback 2.5L 4 cylinder automatic. Over 150,000 miles on the second engine. Original engine I don't know, purchased recently with a used engine from the same model but different ca
HI I recently purchased my new project/commuter vehicle and I noticed a few things were not working on the interior side of the outback. I changed the fuses in the inside cabin panel after a light tester showed that the fuse was not working. After replacing the old fuse with a new one I tested the new fuse and still no change. My issues I have are; the heated switches for the front seats do not work, the window power switches do not light up, out of the two dash board lights that light up the odometer and the time and temperature: the time and temperature doesn't have a light, and I'm not sure but I believe the key ignition should have a light so you have an idea where to insert the key! Well if there is a light that light isn't working either. Besides this I don't seem to know of any other issues but this is my first Subaru so I don't know if I'm missing any other lights or fuses. From what I know the cigarette D/C outlet works or at least the light around it works so I'm assuming it works. Any suggests would be appreciated since my awesome brother whose my teacher in mechanics is in another state so I have to do the work myself and I'm doing this based on the knowledge I know. Thanks in advance for your help!!!
