maybe try 3 drain/fill cycles on the transmission. make sure to check the level while idling after moving the shifter to each gear. If it's slightly low, only put in a halfpint at a time.
check the valve covers gaskets for oil leaks - probably need to hose the engine off to start locating oil leak.
