1 - 2 of 2 Posts
Just back from Subaru after bad alignment experience at TirePros...both the right front camber and left rear camber are out of spec.... I've read conflicting info in the forums about whether or not the front and rear camber can be adjusted??? If they can't how do I get them into spec?? Caster, toe and thrust all seem fine. Any and all info welcome- thank you! :')
on the front, the camber is set by the top strut to knuckle bolt. and the toe is set by the outer tie rod end adjustment.
there is no caster adjustment on the front or rear.
there is no camber adjustment on the rear. no 'stock' adjuster anyway, after market is / maybe available.
the rear toe is adjusted by the lateral? link bolt on the cross member.
1 - 2 of 2 Posts
