Ill start by saying a couple months ago the car had the similar issue with a no start condition it just kept cranking over I did the basic air fuel spark checks. I found out the fuel pump was shot. I replaced it with a OEM Bosch fuel pump and i went ahead an changed the fuel filter too (why not).
This project then evolved into Gates timing belt kit with water pump, spark plugs, plug wires , knock sensor , cam pos sensor and crank pos sensor only because i figured i wouldn't have to do any other maintenance for awhile.
After doing all the work the car started up no issues idled fine, until i popped into Drive and there was a severe delay in the pedal finally after hammering down on the pedal fine accelerated and off i went. No CEL I drove it for a couple weeks like this mostly highway miles and it was fine if I just kept going when i stopped again i would feather the gas and off i went
Now when going to the gas station to fill up i would fill the tank up get in the car and have to feather the gas in order to get the car going while crank it over. I would have to rev the engine for a few minutes to 3 rpm in the hopes it would level out and finally did and off i went
So finally this weekend I jumped in the car and now the car is just cranking over and not starting, i triend feathering the pedal nothing this time :/
I am getting massive amounts of fuel from the main line into the filter and out( did not measure the pressure yet), the ignition coil is firing and all four plugs are wet so I am assuming the fuel injectors are working
