01 OBW 2.5L Saphire Pearl(sold), 01 Ford Excursion, 1975 Honda CL360
Over the weekend I changed my timing belt, water pump, and valve cover gaskets. I took a few pics along the way. You can get the entire kit with the water pump belt and pulleys here and a set of valve cover gaskets here for pretty cheap. Here it goes . . .
Step 1 disable the ignition by pulling this plug:
like this:
Step 2 set parking brake and put vehicle in neutral
Step 3 disable fuel pump by pulling the fuse:
top left fuse in the panel under the dash
Step 4 remove spark plug wires and spark plugs
Step 5 remove washer fluid reservoir
undo front and rear pump connectors
and set on top of fuse box
Step 6 remove and inspect drive belts
Step 7 remove a/c tensioner adjuster
like this
Step 8 I used a compression tester to find TDC on cyl. 1
Step 9 remove valve cover bolts
don't forget this one
Step 10 use a small screw driver to gently crack open the valve cover
Step 11 replace spark plug tube grommets
with new ones
like this:
like this
with new ones
