2010 2.5 Premium CVT
I recently had an audio shop install a new double din CD unit. Since then the climate control does not work as it should, it gives me too hot or too cold with no intermediate area.
With a bit of websearch I found others with this problem. It seems that the aspiration tube that sucks air past the temp sensor is unattached.
By lying under the steering wheel with my head resting on the pedals I can see a white plastic flexible tube with both ends open. One end is attached to the heater body in what seems to be a venturi arrangement. The other end is just lying there unattached.
Is this the aspiration tube?
