FFR5445: What is the record for the car in relation to cardoc's suggestions? (Any reason for the build up?) Also, was the car bought new, or second hand with an uncertain past?
FFR5445: What is the record for the car in relation to cardoc's suggestions? (Any reason for the build up?) Also, was the car bought new, or second hand with an uncertain past?. . . This is a good example of why you should use a cleaner in the fuel, intake and quality oils. And don't go a long time between oil changes. If this wasn't a Subaru, it would be trashed.
No you didn't.The cylinder head is off. No bent valves, no holes anywhere. At first I was all upset because nothing was obvious and this is just so strange. But then I took a closer look. LOTS of carbon build up on cylinder and around valve and valve seat.
What do you guys think? Did I figure it out, or did I take apart my wife's car for nothing!?!?!?
The PCV system allows the engine to pull gases out of the crankcase that are created normally from heat and pressure. At the same time it sucks oil particulates. The particulates adhere to the surfaces of the induction system and over time will thicken. This changes the flow of air. It adheres to the intake valves as well as the oil is pulled through to the combustion chamber. This is that black film you often see on the trottle body. When crankcase pressures are high during high engine rpm, the effect is greater.this thread is crazy.
is there someway the PCV system could have led to this?
if that color was on the plugs - what would it indicate?
It may sound redundant but I second this post. :29:The PCV system allows the engine to pull gases out of the crankcase that are created normally from heat and pressure. At the same time it sucks oil particulates. The particulates adhere to the surfaces of the induction system and over time will thicken. This changes the flow of air. It adheres to the intake valves as well as the oil is pulled through to the combustion chamber. This is that black film you often see on the trottle body. When crankcase pressures are high during high engine rpm, the effect is greater.
Abnormally high crankcase pressure can be due to small things like using heavy oils to ring blowby.
On this engine it appears the valve seals are bad. When the engine is stopped, valves remain open. The oil deposit at the base of the head indicates the oil was draining into the head every time the engine was stopped and the next time it was started it probably smoked a bit until it burned off the loose oil in the chamber. Judging from the photo it looks to have been going on a while. It just got to the point the carbon and sludge lodged the valves open.
It is possible that a clogged PCV valve could accelerate internal leaks. The pressure will find a way out. Given the mileage of his engine, the seals were most likely worn.
Not necessarily. If that deposit was liquid, it would have a smaller mass, but the large amount of deposit at the base indicates it got worse quick. I'd bet the engine was close to a quart low when he pulled it.seems like oil usage would have been much worse than 1qt/4K miles . Does poor oiling lead to this? overheating?
Are you sure they just didn't cut the wires on the "car" side of the plugs? When a company strips a car, the harnesses are cut to expedite removal but all the harness plugs remain in tact so all you need do is plug your car into the engine harness.The root of the problem was the bad the valve seals. There were bad since 125k and created the oil contamination and carbon buildup that you see here. It never ran low on oil and was never overheated. It certainly could have gotten worse at the end. It's not my car and so I rarely drive it. I can guarantee if it did get worse and mass quantities of blue (yes it has always been blue) smoke are pouring out the exhaust, my wife never would have noticed it.
The machine shop wanted $505 to do the valve job. That includes a valve adjustment and resurfacing. He said he does subaru heads all the time although mostly the 4 cylinder variety.
So I decided to go with the JDM engine. I was really worried after googling JDM Engine Depot Reviews. There are some bad experiences out there. But it is a used engine so there has to be some. The sales guy seemed nice enough. He took pictures of the actual engine I was going to buy and sent me a video of them doing a compression test on it. I got the engine yesterday. It seems ok. Only some minor seepage at the bottom of the timing cover. Valve covers are nice and clean. Lots of aluminum surface corrosion but that seems completely normal for its age. My biggest disappointment so far is the engine wire harness was all cut up. Not sure if they need to do that in Japan for some law because it was cut in several places. It's Friday evening, I don't have intake gaskets or fuel injector o-rings and won't be able to get them for several days so I'm trying like heck to swap the harness without pulling the intake manifold. It's not easy but I think I'm going to get it!
road trip!!!!!another issue with the jdm engine (besides the engine harness being hacked to bits) was a dented oil pan; it was shipped resting on the pan. It probably would have worked but i decided to play it safe and swap oil pans.
Got it all back together. The torque converter bolts are tricky, but everything else is pretty straightforward. Only 1 trip to the parts store for exhaust bolts and some rtv. Filled it with fresh fluids and she fired right up. No leaks, no drive-ability issues so far. That 6 cylinder is a smooth engine.
Thanks to all that helped me. I'm off to relax with a cold beer.
