This is how I had everything set up for my '02 Outback Wagon with automatic transmission (AT) for replacement of the front oxygen sensor. I saw everyone talking about it but no pictures, hopefully this helps someone else out.
Tools used:
10mm socket
3/8" drive socket wrench
(Used to take the air intake, and air box off)
22mm Oxygen Sensor removal tool
1/2" drive socket wrench
6" extension
1/2" Flex Socket
Front Oxygen Sensor
Lots of WD-40... Dripping... Prior to removal
Step 1: Remove the air intake
Step 2: Assemble tools as in the picture (I did it from under the car)
Step 3: Loosen once, reset the tool and loosen again if necessary
Reverse procedure to replace, again I had to tighten once, and reset the tools to tighten the oxygen sensor completely. I hope this helps someone, or anyone.
Tools used:
10mm socket
6" extension
1/2" Flex Socket
Front Oxygen Sensor
