Ok, having a long running tail light problem with several different "things" happening. This first started several months ago when the fuse would blow, sometimes several times in a row and other times very random. Took it in and a new multi function switch was installed, seemed to help for about 3 weeks. Next noticed water in the tail light housing, removed red Subaru lens and siliconed it, solved the leak problem. Newest problem is the tail lights will randomly go on and off not blowing the fuse but dash lights will go out and climate control lights will brighten, usually doesn't last long. Noticed sometimes if you adjust the steering wheel it will cause this to happen or you can sometimes get the tail lights to come back on by doing this. Two days ago lights went out again and blew the fuse, tried to replace it several times and it would instantly blow the fuse. Checked the housing and all is dry. Help! Not sure what to do next
