I currently have a 2002 subaru outback base model that i had previously installed a subwoofer system into myself. im pretty sure that everything is hooked up correctly. recently though the system has stopped working properly and now doesnt even want to power up.
problems are that when the radio turns on the capacitor gives off a low voltage warning, when i check it, it goes below 12, and usually sits around 8 to 6 volts, although my obd adapter says that the systems voltage is sitting correctly at around 13.8 volts. i cant figure out what is causing such a drop, where, or why its not effecting anything else in the car.
could it be a bad around? if so could someone suggest a really good place to put a sturdy ground for the amp. or could it be my alternator or something.
if needed, 2.5l 4cyl subaru outback base model.
340 dual XAF340. BOSS 2300w subwoofer dvc. 2 farad capacitor.
help is most appreciated!
