Working on replacing old radiator with new one.
The must be a trick to disconnect the four pin connector and should would appreciate detail steps.
Moderate pulling not working.
2001 Outback Wagon 3.0 VDC
From the orientation of the photo, top right there is a tab that needs to be pushed in while wiggling the connector and pulling apart at the same time, it will be a pain in the butt as it will have a few years of dirt build up to fight you. Persistence is key.
Just make sure that tab is pushed down as much as possible.
2001 Outback VDC Wagon
If you can, a squirt of silicone lubricant along with a wipedown with isopropyl alcohol can help. As Grum said, grime and dirt can seieze the mechanism, but with enough tenacity it will come free.
