Hi everyone!
A couple weeks ago I noticed a terrible sound coming from my alternator. Upon opening the hood I could smell her burning up. Multimeter readouts were in the 11-11.5 volts at idle.
So I bought a used alternator on eBay that was supposedly tested. Upon installing that my voltage (no accessories on) at idle at the alternator and battery is around 13.7 volts. If I rev up the motor to 2000 rpm I can see the voltage fluctuate to 13.9, but never 14 or above.
I then tested with my multimeter at the alternator and battery and under load with such accessories such as my headlights and my ac fans running, the voltage at idle is 12.5-12.7 volts. If I rev it up with accessories on, the voltage will go to 13.4-13.7.
Never once with this used replacement alternator have I seen 14 volts or above.
Does the above situations and multimeter findings, seem normal or is the replacement used alternator not working up to capacity either?
