Hi All,
I have had my subaru since last April and it now has 68k miles as it is a commuter car, 70 miles/day in Kansas. I have removed the cross bars on the roof rack to improve mpg and want to take off mudflaps but I am unsure if it will look bad. Does anyone have experience with that? Also, what's the max psi for tires. I want to try 35 on all 4 to see of it helps with mpg, can I go higher? Will it help? And what are the dangers of doing that? I'm averaging 22 mpg and I'm trying to just save some gas. Has anyone made a grill block and can you use it year round or just in the winter?
Also, wanted to know of the following maintenance someone can do themselves with average common sense. Suggestions in addition to these?
Brake pads
Brake fluid flush
Coolant flush
Spark plugs
Cabin filter
Thanks,
Jess
Brake pads
Brake fluid flush
Coolant flush
Spark plugs
Cabin filter
Thanks,
Jess
