I attach a recent diagnostic test. could anybody help how to solve it? CAR model is OUTBACK H6 2004 AUTOMATIC
Diagnostic Scan
Vehicle diagnostic report
Shop Name: B16A Workshop Address: Marathonos Avenue 448 Phone: 2294091000
Email: [email protected]
VIN:
Year:
Make: Subaru
Model:
Odometer:
Vehicle Software Version: V24.50
Diagnostic Application Version: 1.00.037
Test Time: 2020-08-01 11:03:49
Diagnostic path: Europe > Outback > Other Years > Health Report
Diagnostic Result
Fault
EOBD
( 6 )
Inspection Result
( 10 )
Abnormal
P0050 HO2S Heater Control Circuit Bank 2 Sensor 1 Current
P0700 Transmission Control System (MIL Request) Current
P0302 Cylinder 2 Misfire Detected Current
P0304 Cylinder 4 Misfire Detected Current
P0306 Cylinder 6 Misfire Detected Current
P0741 Torque Converter Clutch Circuit Performance/Stuck Current Off
P0731 Gear 1 Incorrect Ratio Current
P0732 Gear 2 Incorrect Ratio Current
P0700 Transmission Control System (MIL Request) Pending
P0731 Gear 1 Incorrect Ratio Pending
ECM (Engine Control Module)
( 7 )
Abnormal
P0700 AT MIL light on required
20B12 Preparatory Codes
20B02 Preparatory Codes
P0050 O2 Sensor Heater Circuit Range/Performance(Bank2 Sensor1)
TCM (Transmission Control Module)
ABS (Anti-lock Braking System)
( 4 )
( 1 )
Abnormal
P0741 Torque Converter Clutch Circuit Malfunction
P1706 AT Vehicle Speed Sensor Circuit Malfunction(rear wheel)
Abnormal
C0045 TCM malfunction
IUM (Integ. unit mode) ( 2 ) Abnormal
B0201 CAN-HS counter abnormal
B0223 CAN-HS VDC/ABS no-receive data
CS (CAN System) ( 1 )
Abnormal
U1223 CAN-HS VDC/ABS no-receive data(Fault Location: Comm.Line Failure(VDC/ABS to Integ. Unit) or VDC/ABS Failure)
Normal
( 0)
multiple codes would indicate an electrical issues based upon the above that I have condensed here
Diagnostic Scan
VIN:
Year:
Make: Subaru
Model:
Odometer:
Diagnostic Result
Fault
EOBD
( 6 )
Inspection Result
( 10 )
Abnormal
( 7 )
Abnormal
( 4 )
( 1 )
Abnormal
Abnormal
Abnormal
Normal
2001 VDC/SC One of a Kind
Did all this pop up at the same time or did the trans start acting up and you got it scanned? How long has the engine light been on?
First place to go is the battery.
Then grounding.
Check your trans fluid level after the car warms up.
After that's all good then we can move forward.
Outback 2011 3.6R Premium
The last time I read a post with similar errors I believe the problem was the main ground/earth wire from the battery to the engine was not re-connected (after other work had been done).
Check your battery and ground/earth connections first.
Seagrass
