Indeed, the information we have needs clarification and some additional observations/answers.
I would think that much, if not all, of what we have offered would have been considered, and tested out, by the mechanic and the Subaru technician, certainly before going as far as changing the ECU. But again, only a few suggestions, such as the TPS, have been mentioned by HeartMan, so we don't know what else, if anything, was already considered.
In this regard, IF they suspected the brake booster, it would have been a very simple task to disconnect and block the vacuum line off the manifold and then see what happens, in which case, HeartMan could confirm this so we can set it aside.
Also, as was mentioned earlier, by using a scanner that can monitor and log the engine parameters, there would be information on manifold conditions, fuel trim, injector performance etc. The Subaru Select Monitor can do this, as can RomRaider Logger -- but the technician has to go through the motions, and then analyze the data (know what to look for). Was this done? We don't know -- but if it was, what was found?
I guess we'll have to wait until HeartMan gets back to us.
