the auto trans made a change in 99/00 and they went from a 4 bolt / 2 pin system to an 8 bolt / 2 pin? system.
this is just a guess but i think you have a 96 - 98 short block.
the starter mounting may be an issue since the bolt hole change affected that as well. you can probably use it as long as you can mount your starter. i don't think the specs for the crank and pistons are any different. ALTHOUGH, they may have moved the thrust bearing. i don't know when they did that. maybe pre- 99.
the older style starter used one long trans to engine bolt and one nut on a stud in the trans bell housing. the newer trans use more / all bolts i think. i can't remember. (i know some of the bolts around the starter have to be done in the right order or your wrench/ socket will not fit on the bolt head.)
i would contact the supplier and ask. see if you got the right part, or if they messed up. see what they say about using it.
