2005 Outback 5MT
I recently got a 2005 Outback, so far the only issue I'm having is with the driver's door lock. It's currently stuck open, will not lock with the key or the remote. I took the panel off today to put in a new window switch assembly and noticed that the white plastic piece on the lock actuator cable was broken. I messed around with that before deciding I'd need to replace it somehow, put the door back together, and it then wouldn't unlock. I managed to pry it back open from the outside while turning the key, and it's back to not locking. So at least I can get in without climbing over the passenger seat.
My question is, how do I go about fixing this? I'm not finding the cables for sale anywhere individually, they all come attached to the full actuator assembly. Which is kind of pricey at $60+. Can I just get a cheaper actuator for any of the other doors (coming in around $20 each), and just pull the cable off that and attach it to the driver door assembly? Or is the whole unit nonserviceable? In which case, has anyone figured out an alternative for these little plastic pieces on the cables?
For reference, here's the piece I'm talking about:
497872
$60 doesn't sound bad. You have already done the hard work taking the door apart. You could try a "you pull it" place.
Sent from my SM-G965U using Tapatalk
The white cable that's at the inner door handle assembly shown in the diagram above goes to the latch assembly on rear part of the door. Both the outer part of that cable and the inner moving wire are attached to the latch assembly in a way that it can't be replaced without removing the latch assembly from the door, at which point the whole assembly might as well be replaced rather than just the cable.
The question that I have is whether or not the white lock/unlock cable, if it were properly attached to the inner door handle assembly, would work, i.e., would rotating the manual lock control on the handle assembly allow the latch to be locked and unlocked?
The center part of the cable moves in and out about 1/2-inch. When it's pulled out from the cable the door latch is locked; when it's pushed into the cable the door latch is unlocked. If that doesn't work to lock and unlock the latch assembly, then there's a problem at the latch assembly itself in addition to the broken plastic retainer at the inside handle end of the cable.
2005 Outback 5MT
I’ve actually started to wonder that as well, because when I hit the lock button, nothing seems to happen to the driver side lock. I don’t hear it trying to actuate anything. I’m just going to go to the scrapyard and pull out a replacement assembly, will update if that works.
2005 Outback 5MT
Update: I changed out the lock assembly with a junkyard part (only $25!)
The door locks now! Remote and both the exterior/interior locks work perfectly now. The outside handle still sticks just a tad, sometimes have to pull it twice to get the door to open. But it was doing that before, so I’ll just live with it now that it’s actually locking. It’s a good thing I did replace the whole thing, it seems the old assembly wasn’t actually working because now that I’ve messed around with it, I’m pretty sure the remote lock should’ve still been working. That broken plastic part only seems to control the interior handle lock.
Side note, this is not an easy job. There’s not a lot of space to work with and there’s no actual trick. You just have to sit there and shimmy it and struggle to get it into place. I also found that some electrical tape holds that plastic piece just fine, because the junkyard part I got had the exact same part broken. The lock worked without it, but the interior lock was still sticking. If you don’t need to replace the whole assembly, as in the remote and exterior locks work, but just the interior lock is broken because one of those plastic doodads is broken; just wrap it up in tape! Works fine.
