2005 3.0L H6 automatic - fault code p0768
1043 1
Hi there. MY outback has fault code P0768 which means there is a fault with the drive solenoid (Solenoid shift D) this means when driving it doesn't change into the best gear needed and causes problems. I want to inspect it and see what is causing the problem I.e. if it's a connection issue.
Does anyone have a blueprint or labelled picture of what's underneath the gearbox sump when removed and where I can find the solenoid I'm looking for?
1 - 2 of 2 Posts
I see you are in great britian. (so that is like a 2006 US/Candian).
does yours have VDC?
you might find service manuals here (in those below some of those H6 cars have VDC, and some don't in 2005-2006, so the electronics trans maybe different between the 2)
Subaru Factory Service Manuals (FSM) - Every Model - USDM/EU
1 - 2 of 2 Posts
