So are you happy with your 2005 OBXT 5MT? I'm considering buying one for my son to borrow to get to school (a commute). Any words of wisdom or warnings???
So are you happy with your 2005 OBXT 5MT? I'm considering buying one for my son to borrow to get to school (a commute). Any words of wisdom or warnings???When I bought the 2005 OBXT 5MT, I had a bunch of competing priorities.
Since I was coming from a 2011 Outback 2.5i Limited, "Fun to drive" was more toward the top (since the 2011 Outback wasn't fun at all).
Now that I've has the 2005 for a few months, I feel like my focus is more on dependability / reliability.
I'm PROBABLY going to replace the Outback in / by / around 2015 (and I typically only drive around 5K miles/yr), but the future is awfully hard to predict.
XTs are fast and fuel-thirsty compared to any other version of the car. They also don't really tolerate deferred maintenance. Normally that would be a recipe for disaster when combined with a student lifestyle & budget, but I don't know you or your son. Just keep it in mind.So are you happy with your 2005 OBXT 5MT? I'm considering buying one for my son to borrow to get to school (a commute). Any words of wisdom or warnings???
No, that's not part of the 105K as far as I can ascertain.Did you have your valve clearance checked as part of your 105k service?
I need to go through the previous owners service records again. I found where the dealer recommended changing the coolant, but I don't see where it was ever done.The coolant should have been changed at 90k, and should be changed again at 120k. If you are unsure about what happened during the time belt change, I would make sure it gets changed at 120k, and remember the Subaru 'special sauce.'
Yes, that's exactly the issue. That and water pump failure because there is no lube left in the antifreeze.
Tom
It's my understanding you should really like the motor come up to temperature before you start stressing it / the turbo.So are you happy with your 2005 OBXT 5MT? I'm considering buying one for my son to borrow to get to school (a commute). Any words of wisdom or warnings???
Call the shop that did your 105k service and see if they put in fresh antfreeze. I don't think you're sure on that point yet.I need to go through the previous owners service records again. I found where the dealer recommended changing the coolant, but I don't see where it was ever done.
Lets say it wasn't done -- how big a deal is it to wait for the 120K? I definitely plan to have it done at 120K. I'm just not especially excited about doing it 105K and AGAIN at 120K, and I would really like to be in sync with the maintenance schedule.
Received an e-mail reply from the shop (not the mechanic). They said MOST of the coolant was replaced with the 105K service, and no problem waiting until the 120K.Call the shop that did your 105k service and see if they put in fresh antfreeze. I don't think you're sure on that point yet.
If the fluid has been in there since 60k, you should get it changed. Can't really tell you what waiting another 15k will do.
