Recently my remote entry stopped working. As well as when I remove my key from the ignition, it does not stop chiming.
All doors manually lock and unlock fine with doors closed. However if a door is open and you manually lock doors they will lock and immediately unlock like the key is still in the ignition.
All the fuses check fine. Changed the remote battery still doesn't work, programmed a new remote into the car and it acts as though it accepted it, but it will not work either when tried.
Any help would be appreciated, otherwise I may need the dealer for this one.
