I have a 2006 Outback 2.5i Ltd, and the airbag light has come on since it has been cold out. On warmer days, the light will randomly display. So, I had the dealer run a diag on it, since my car was in there for a transmission issue. When I picked up my car, the dealer told me the light wasn't throwing any type of code, and they found the issue to be a burned out LED bulb, located in the map light overhead console. This is the passenger ON/OFF light, and sure enough, if I tapped on it, the light would flicker. I asked how much it would cost to fix, he said it would be around $340 (- the $65 i paid for the diag), and the whole overhead console would need to be replaced. SO for a burned out bulb, it would cost me $270...are you kidding me??!! I now understand why so many refer to the dealer as the STEALER. Unbelievable. I was told that since the airbag light was on, the airbags would not deploy.
So, I jumped online, and found the overhead console (OEM) sold for around $115. I looked at mine, and figured out how to remove it .... remove the lens, and 2 screws secure it. So, now I am looking at the cost of the part, installing myself, and saving the ridiculous $160 installation fee (I guess it is $80/screw).
I figured since I had mine out, I might as well look at it. I removed the PCB that contained the 4 LEDs. With closer inspection, I could see one of the components on the board was loose...as in there wasn't enough solder to secure it. So, I whipped out the old soldering iron, and bolstered it a little. I may have added a little too much, but it was the best I could do w/ the tools I have @ home (better lab tools @ work). Anyway, tested it....works perfectly. In the pic below, I have called out the component that was loose.
I'd like to know what you all think about it. If it's a legit fix, hopefully I help someone else.
