1 - 2 of 2 Posts
error 22 or "Er SS"?
What type (Subaru, aftermarket) of wheel bearing/hub was installed?
ABS depends on a magnetic ring at the back of the hub for the wheel speed sensor. If the ring isn't correct, is damaged, or if the sensor was damaged during the work and that wheel's signal is not getting to the ABS control module, it can lead to trouble codes.
Use the 2006's on-board code reader to see what ABS-related codes are appearing: 05, 06-09: How To Read Diagnostic Trouble Codes (DTCs) | Subaru Outback Forums
1 - 2 of 2 Posts
