A week ago the check engine light came on and the cruise control indicator started flashing. It ran rough for a bit and then was OK.
Later I checked and I got these OBD codes:
P0016 - crankshaft position cam shaft position correlation bank 1 sensor A
P0018 - crankshaft position cam shaft position correlation bank 2 sensor A
P0021 - camshaft position timing over advance OR system performance bank 2
I went to start it again a few days ago (I only drive it about once a week) and it would start but then quickly stall - not drivable.
Has anyone had experience with these codes and this situation and what ended up as the problem(s)?
2006 outback 3.0L with about 205K miles.
Thanks!
Thanks!
