So this morning about halfway to work, I pulled up to a red light, put it in neutral, and let the clutch out, as you do. Then trying to take off again, it was quite difficult to put it into 1st through out the push until it was all the way, then back out of 1st was difficult as well. 2nd was fine, but then it would not go into 3rd, 4th, or 5th at all. After I moved the shifter in neutral back and forth ALL the way to each side, it seemed like 3rd-5th 'unlocked', and I was able to shift normally. But now every time I use 1st, which is still hard to get into and out of, it seems to 'lock' 3rd-5th until I move the stick side to side in neutral all the way to each side. This has never happened before and I checked the tranny fluid and there is fluid in it, so that shouldn't be it. The car is coming up on 300km, is it just on it's way out? Or is this an issue that is known?
