1 - 20 of 22 Posts
Hello i have a legacy 2007 Ez30 with a misfire problem.
Not always but when starting the enigine it will misfire for a second or less.
No misfires when driving only when start cold or warm.
One time i got a pending p0174 code with the tourqe app but there is no cel light on.
Maf sensor was dirty as **** so i clean it up and later replaced it.
Lambda sensor is replaced but the problem is still there.
Now i need your help to solve this annoying problem , what is the most common problem on these engines?
lambda = the front o2 = front air fuel sensor. (lambda is not a typical term used here)
age / type of spark plugs? (this car takes NGK iridium,...and may not like others,...or they will fail quick).
_____
do you have a windows laptop to get some logs with free rom raider?
Sorry i live in Sweden and here we call it lambda sensor.
The sparkplug was replaced at 10500 km (now at 17000km) .
Dont know what brand or type they are.
Discussion Starter #10
How long does your H6 engine crank before start?
2 seconds or instantly?
Yesterday when driving for about an hour i turned of he car for about 15 minutes and when i crank the engine it cranks twice the time as usual.
03 H6 OBW & 06 WRX Sportwagon
older soobs sometimes have fuel leaks at clamps under the hood, worse in cold weather, - maybe you're losing fuel pressure in the rails? tighten every screw clamp you can find on the fuel lines.
Discussion Starter #14
Hmm might this have something related.
When my gastank is almost empty it start to missfire even more when starting the car?
here, parts retailers will loan/rent tools - maybe measure your fuel pressure?
Master Caster
100% second on that.
Low on fuel bad, and if you even noticed a change.
Master Caster
This sounds more and more like fuel pressure. Turn on you key, but don't crank. Let the key on for 10-15 sec and then try. If it fires right up, my suggestion is there is a lack of fuel pressure. Waiting the 10-15sec will let the fuel pump duty cycle run at max until you are pressurized and then not issues.
There is also a common o-ring issue in the fuel pump assembly. More an issue with turbos, but still something worth investigation.
Discussion Starter #18
Hello i still have the problem noone can find the reason of.
But some days ago i noticed i can replicate the misfire.
If i hold the gaspedal at full throttle it will stumble/misfire right at the starting moment.
Will this give any clues?
are you getting long crank after clearing codes? My 2010 Outback 3.6R did that when I cleared the p0420 codes, after that start it has been fine. check for vacuum leaks and or cracked hoses in the intake tract.
1 - 20 of 22 Posts
