Hello
2007 outback basic wagon. Main ignition key is worn out and will not open door and has started getting tricky with ignition as well. I am using the valet key as a backup but it has a plastic back loop which will eventually wear out and break...the valet key does not seem designed for everyday use.
What is the best / least expensive way to get a chip key like the one below, with a metal back that does not get worn out? It seems like going to a dealer and paying a gazzillion is one of the options...
515982
Super Moderator
Outback 2011 3.6R Premium
Most locksmiths should be able to supply the key, cut the key and clone the chip.
Seagrass
1995 Legacy 2.2L | 2005 Outback XT 2.5L
I think you can take the key apart and get the little transponder out of it so that you don't have to get it reprogrammed. Just get a new key cut and transfer the chip.
