I'm pretty sure one of my front bearings is making noise. How do you know which bearing is the noisy one? Its hard for my ears to tell which side of the car the noise is coming from. It almost sound like tire noise.
I will have to disagree with changing bearings on both sides of the car. Bearings do not have to be replaced in pairs. I will agree when brakes pads go bad on one side, you'll have to do the other side. Wheel bQuite frankly I don't think it matters. If one bearing is bad, you'd probably want to change both sides at the same time anyway.
No reason to replace bearing until they have noise problems. I replaced my first REAR bearing probably around 60,000, second one to go bad was the front (same side) at around 140,000 miles. Now, I have another one growling and I actually think it is the same on as the first to go bad. Should have used a better quality part I guess.Actually, yeah you're right. It's just that if you learn how to do it on one side, you could do it on both and save yourself relearning how to do it on the other side when that goes out. At my age 2 years is enough time to forget how you did it the last time.
With egg on my face, if Joe finds out his 2 year old bearing went out again while the original one is still holding up, I'll have double egg on my face.:surprise:
Spinning the wheel on an AWD vehicle is not an easy task, you are trying to spin more than one wheel and they don’t really spin freely enough to feel any vibration.Jack it up, put hand on spring, spin wheel -- You'll feel it.
Not so. I work on AWD vehicles all the time, and not just Subaru; BMW, Mercedes, Nissan, Toyota, Chevy, Land Rover and Dodge. The wheel will free spin off the ground just as it is able to turn freely in vehicle maneuvering when driving. The differential allows for slip. You'll also be able to tell if the bearing is loose by grabbing the top and bottom of the suspect wheel and try to wobble it. Movement is bad and don't drive it.Spinning the wheel on an AWD vehicle is not an easy task, you are trying to spin more than one wheel and they don’t really spin freely enough to feel any vibration.
:loveawd:
I've seen this in action. Grab the spring or hold a wrench or something against it while the wheel spins. Ideally with the car on a hoist and the car idling in gear. Quick and easy to check all 4.Jack it up, put hand on spring, spin wheel -- You'll feel it.
I definitely have a whiner, but no movement when I grab the wheel. That was the first thing I tried. When I try to spin the tire, opposite tire spins with it. I might give another try to jacking up all wheels and letting the car do the spinning.Not so. I work on AWD vehicles all the time, and not just Subaru; BMW, Mercedes, Nissan, Toyota, Chevy, Land Rover and Dodge. The wheel will free spin off the ground just as it is able to turn freely in vehicle maneuvering when driving. The differential allows for slip. You'll also be able to tell if the bearing is loose by grabbing the top and bottom of the suspect wheel and try to wobble it. Movement is bad and don't drive it.
I have had very good experience with the SKF, on my Jeep even, for the $$$ they better be good.Replaced with SKF, and again covered mating surfaces with anti seize. I also replaced the bolts holding the bearing, which are STARRED items in the FSM
