1 - 12 of 12 Posts
2008 Outback 2.5i Touring 5MT
I have a '08 Outback 2.5 manual with ~45000km on it. We started hearing a metallic rattling sound about 2 months ago and it has gotten increasingly worse over time. The rattle only occurs at specific engine rpm (1400 & 2800) and there is no link to vehicle speed, transmission gear, etc. just rpm.
I originally thought it was the doughnut gasket with the spring bolts between the catalytic converter and the muffler leaking. There was water dripping from the flange when I started the car up cold. I replaced it with an after market gasket / bolt kit. It didn't seem to solve the problem as there is still water dripping and the noise is getting worse. Interesting to note that the factory springs for the gasket were fully compressed when I broke / removed them. My next thought is to try a factory replacement kit as I have read that the aftermarket kits may not fit perfectly.
I have also looked at the heat shields and could not find any that appeared to be loose. The fact that rattles occur at multiples of engine rpms (1400 & 2800) implies that it might be a harmonic vibration frequency causing these to vibrate.
Any advice on potential solutions would be greatly appreciated!
Although it's possible, I tend to doubt the rattle is coming from that exhaust joint, but it could be something in the exhaust system somewhere (which could be more related to engine speed).
Is it only when the engine is under load? Have you tried to reproduce the noise with the car stopped, or up on a lift, and the engine revved to 1400 rpm? This should make isolating the source far easier.
heat shields were my first thought so, I guess I'm just gonna lurk to see what it turns out to be.
2006 Outback 2.5i Limited 5MT, 1984 Porsche 944
I think it's the heat shields still. I couldn't tell that mine were loose, but I noticed that my car was missing a heat shield clamp after studying a diagram for the system. Must have rusted off.
I slapped a cheap hose clamp to it, and the problem is gone. The clamp that was missing is the one right where the tubing attaches to the manifold.
Thanks for everyones thoughts so far. I can reproduce the noise while on blocks with no load. There doesn't seem to be any change in the noise with temperature, engine load, speed, etc.
I originally thought the sound was due to a leaking exhaust joint because the sound was more of a growl. But over time the sound has become more metallic and sounds more like heat shields. I haven't been able to get someone to rev to 1400 rpm while I am under the car yet. That is my next step.
just for quick diagnosis, you could throw some zip ties around the shields, get in and rev the car. Then remove the ties one-at-a-time to pin down which shield is the problem. I'd do it on a cold vehicle.
2009 Outback 3.0R Limited
My heat shield was rattling at that rpm despite nothing apparently missing or broken or worn-looking. I reached under there while my wife gave it a little gas. I was able to move the whole thing up about a 1/4 in., stopping the rattle.
A hose clamp has kept it quiet since.
I'm leaning towards heat shields as well. I had a heck of time finding which of mine were rattling, until I got it on the ramps and saw/felt that it was both of the shields around the exhaust pipes just aft of the manifolds. They looked fine and the space between them and the pipes was about 1/32 of an inch. Just enough to cause a vibration at certain RPMs.
It turned out to be heat shield rattle just aft of the catalytic converter. A very small amount of movement caused such a great noise. I used the tried and true hose clamp method and all is quiet. Thanks for all the responses!
2006 Limited Outback wagon
First post, sorry to be bringing this thread back from the dead, but I did not want to start another thread about this problem. There appear to be many threads about loose heat shields already, so I picked the newest one :).
My 2006 is having the same rattling coming from the heat shield around the pipe from the drivers side exhaust port to passenger side up-pipe. It looks to me like some kind of stainless steel wool material packed around the ends of the heat shield has compressed or fallen out. I searched for exhaust packing, and steel wool here and saw no results. I am wondering if this was a repair done by the dealer or mechanic in the past, or am I the first person to ever notice this factory installed packing? (We are the original owners)
Can this material be repacked or replaced?
Rob
2009 Outback 2.5i Limited
Rob, did you ever solve your problem?
My heat shields started rattling something fierce in the past month or so.
I crawled under there today and poking around, found lots of possible suspects. But no obvious rusted out attachments. I started by looping some wire around the cat shields and tightening that down. No luck, it must be the ones in the engine compartment. With the plastic shield on this year's model it's hard to get up in some areas.
Any ideas from the gallery what to try next?
Dave.
Found it.
The exhaust pipe exiting the catalytic converter was rattling. The heat shields were not tightly gripping it at that point, close to a 1/4" gap, despite no obvious missing or broken parts of the shields themselves.
Following the techniques in another thread, I took a stainless steel deck screw and drove it, as a wedge/shim, between the pipe and the shields.
While looking around at the other shields, I noticed that some had some expanded metal fillers whose purpose seems to be to reduce vibration but maintain contact. Perhaps one fell out of this joint.
Dave.
1 - 12 of 12 Posts
