2008 Outback 2.5i, 2009 Forrester 2.5 sohc
I'm coming up on the next 30K service, with 177,500 on the car. I do the service myself, and religiously do all fluids, plugs, filters.
I was going to replace the plug wires (last changed at 100K).
I replaced the ignition module at 110k as PM.
I was going to replace the tensioner pulley and belts.
Throttle body gets cleaned once a year.
Any other PM you would recommend in addition to the 30K in the manual? Since I do the work myself, I don't mind spending a little more on parts.
The car has been remarkably reliable, and still looks great cosmetically. Next year she will get her third timing belt.
I own 4 Subarus. A 95,97,02 and a 14. The first two are 2.2 and the last two 2.5.
i'm surprised that the alternator and starter have lasted that long! Same for the knock sensor.
'18 OB 3.6R
Not required maintenance per-se, but my 05 legacy definitely needed every rubber bushing in the suspension at 200k. Get fired-up for that job eventually.
where is the Knock sensor located on the 08 2.5L SOHC? Its a donut shaped sensor with harness leads? I couldnt spot on the block when I looked.
03 H6 OBW & 06 WRX Sportwagon
you might use a turkey baster or similar and swap-out some power steering fluid.
try to blast-clean the condenser/radiator out - even between them.
kinda wonder when to swap the big radiator hoses for PM?
maybe lube the locks and hinges?
I remove the PS fluid and refill once a year. Hoses were changed with the last timing belt.
