I was about to replace the spark plugs on my 09 Outback 2.5 (90k) when I noticed oil near the top of the spark plug cable boot as I pulled it out. There is no oil down inside the tube just near the top. I went to the dealer and after providing my VIN number I purchased two valve cover and four spark plug tube gaskets for $75.00. Once back in my garage I started on the passenger side and removed all the 10mm bolts on the valve cover.
Now I'm faced with two problems. First I was able to pull the cover off but unable to get it out as there is very little clearance because of the frame. I tried removing it from the top, bottom and backward and forward with no luck. I was able to reach in and remove one of the seals/gasket on the top of the spark plug tube and to my disappointment it did not match with the new ones I had just purchased from the dealer. Mine area a bit larger than the new ones which are part number 10966AA030 so I plan to take them back to the dealer tomorrow.
Can anyone give me some advise on removing the passenger side valve cover and is there a trick to removing the drivers side valve cover also?
