Recently replaced both front Lower Control Arms (OEM), sway bar links front and rear (MOOG), struts (KYB G-Excel), Strut mounts (KYB). The rear struts were replaced first and the handling improved (test drive) did everything else in one go, and it drove worse. Worse as in floaty and less connected. It seems like the front is riding a little higher. I didn't replace the springs. For the record, I've owned this for less than a year, so it's possible one of the previous owners had higher quality shocks up front..... Everything lined up good and looked to match what was being taken off. Did have the alignment done afterwards.
