I changed my front and rear brake pads on my 2010 Subaru Outback yesterday ... after 106K + miles, they still had a lot left to them, with no uneven ware. Instead of hanging the calipers, I removed the fluid line at the caliper, with a little brake fluid draining into a bucket ... the fluid was clear and clean. After getting everything put back together, I topped of the fluid in the reservoir to the proper level. In my test drive around the neighborhood, the brakes are still going to the floor with minimal stopping power. If I pump the brakes rapidly, I will build up the proper pressure. But the next stop, the peddle will hit the floor again. Am I missing something? The fluid level has not dropped, and I have made sure that the fluid lines were reconnected to the calipers securely with no leaks to be seen?
