Intro
2011 Outback 2.5i CVT PZEV
67k Miles on original CVT and Differential fluids. Mainly highway miles with occasional towing.
I decided to take the plunge and change the fluids myself. After several hours of research, I discovered Redline CVT fluid. It is Subaru certified and for use with metal CVT belts/chains. There seems to be a lot of questions on how to change the CVT and Diff fluids so I thought I would share my experience and what I learned. I'll report back if I have any issues or learnings.
CVT Fluid Change
Fluid:
Manual says total capacity is 12.7-13.2 qts, I drained ~6.0 qts and filled with ~5.5qts.
- I used Redline Non-slip synthetic CVT fluid purchased from Amazon.com. This one: https://amzn.to/2MDyYvW
-You must check the level with the car level, idling, and in park at operating temperature. I have a 4-post lift which makes it easy to do.
Tools Required:
-10mm Hex required for fill Plug, 36.9 ft-lb.
-8mm Hex required for drain Plug, 14.8 ft-lb.
Sequence:
1. Remove fill Plug. Since my fluid was warm and not hot, some fluid drained after removing.
2. Remove drain Plug and drain remaining fluid.
3. Re-install drain plug and torque to 14.8 ft-lb.
4. Fill via fill hole until fluid runs out.
5. Install fill Plug and tighten.
6. Start and idle vehicle to warm fluid. Cycle transmission through all positions.
7. Check fluid level and fill if required. Torque Fill plug to 36.9 ft-lb.
Front Diff Fluid Change
Fluid:
-Manual says capacity is 1.4-1.6 qts, I drained ~1.5 qts and filled with the same amount.
-Fill via vent hose accessible from engine compartment.
-I used Redline 75w-90 synthetic gear oil purchased from Amazon.com. This one: https://amzn.to/2HZTVOf
Tools Required:
-T70 Torx for Drain Plug, 51.6 ft-lb.
- 14mm socket for fluid check plug, 25.8 ft-lb.
Sequence:
1. Remove vent hose prior to draining.
2. Remove drain plug and drain fluid.
3. Remove fluid check plug.
4. Clean drain plug of any metal.
5. Re-install drain plug and torque to 51.6 ft-lb.
6. Fill with 1.5 qts till check fill overflows.
6. Re-install fluid check plug and torque to 25.8 ft-lb.
7. Re-install vent hose.
Rear Diff Fluid Change
Fluid:
-Manual says capacity is 0.8 qts, I drained ~0.75 qts and filled about the same amount.
Tools Required:
-13mm Square for Fill Plug, 36.1 ft-lb.
-13mm Square for Drain Plug, 36.1 ft-lb.
-I used a 1/2" drive ratchet but a 13mm socket is on order.
Sequence:
1. Remove fill plug.
3. Clean drain plug of any metal.
4. Re-install drain plug and torque to 36.1 ft-lb.
5. Fill via fill hole until fluid runs out.
6. Install fill plug and torque to 36.1 ft-lb.
CVT Fluids:
Redline - http://www.redlineoil.com/product.aspx?pid=128&pcid=9
Valvoline - http://www.valvoline.com/products/brands/valvoline/automatic-transmission-fluid/136
Eneos - http://www.eneos.us/product/7
Subaru - http://www.subarupartswebsite.com/OEMParts/subaru-153/S/SOA868V9245.html
Reference Pictures:
CVT Fluid Change
Fluid:
Tools Required:
Sequence:
Fluid:
Tools Required:
Sequence:
Fluid:
Tools Required:
Sequence:
CVT Fluids:
Reference Pictures:
