2011 2.5i Limited - P0171
7670 8
Been to the dealership 5 times since the end of December and had an O2 sensor replaced the last one. Car is completely stalling, RPMs jumping around and hesitations, and is almost impossible to restart after getting fuel.
Anybody else had this? I'm headed back to the dealer tomorrow and since I'm at 52k miles I'm out of warranty, the O2 sensor (which wasn't the fix apparently) came out of my pocket. Just looking for ideas as to what anybody else might have seen.
1 - 9 of 9 Posts
When you fill up the fuel tank, it is difficult to start?
P0171 is system too lean. Not enough fuel or a vacuum leak after the MAF.
If the dealer diagnosed a bad AF sensor and it did not repair the issue, then they owe you a freeby diagnostic. Call and talk to the manager and see what they will do.
Based on your state it might be covered under your emissions warranty. Check.
Update: Just got back from the dealership, they tested the usual suspects (mass airflow, fuel trims). Said the fuel trims were leaned out to their maximum position. Airflow sensor was fine. Started to check for vacuum leaks (wish they would have finished) and found the air inlet boot clamp to be loose. Tightened that and sent me on my way. Have to admit, I'm still skeptical.
I went straight to the gas station, filled up, and it started right up. Drove it on the highway and some back roads on the way home and didn't have any stuttering or idling issues. I had seen some similar issues years ago with an old Pontiac and was able to find the loose culprit then, but looking at the Outback I never saw anything out of the ordinary.
So, we'll see. An air issue makes sense with how it ran but after 5 dealer visits I can be nothing but skeptical.
Go figure.
Not surprising given they replaced the AF sensor that wasn't the problem. I will say that if there was a loose connection after the MAF, they probably made it the first go round.
Fuel, Air, Fire in the proper mix and timing is needed for complete and accurate combustion.
Somewhere in the chain of events that operate the system to achieve the perfect mix, you have too much air and not enough fuel.
I would suggest printing out the following and handing it to the service manager for reference. Maybe they don't have access to a flow chart to help them when they have no idea where to go to look for the issue.
1 - 9 of 9 Posts
