My 2012 Outback has about 25,700 miles on it and is a bit over 2 years old. It's run well, and I've been happy with it to this point.
Recently, I've noticed an increasingly annoying low-pitched creaking or rubbing sound coming from the rear of the car. This sound occurs on all roads (smooth and rough), at all speeds, and in either direction (forward or reverse). I've removed everything out of the back of the car and have folded the rear seats down in order to try to isolate where this noise is coming from. After removing the cargo cover, the noise actually increased.
One thing I should note is that I've felt that the rear suspension has always been a bit stiff. Not sure whether that's normal or not. By stiff, I mean that the rear wheels will bounce over a parking lot speed bump rather than absorb it like the front wheels do. (This happens even at very low speeds.) This led me to think that perhaps there's a problem with the rear suspension that's also causing the creaking noise. But when I push the rear bumper down and let it "rebound", it appears normal and there's no creak.
So, does anyone have any idea what might be causing this creaking noise? And are there any opinions about the car's rear suspension? (ie - normal/abnormal?) Would this sort of thing be covered under warranty? The noise is really annoying and I feel that a 2 year old car with only 25K miles on it shouldn't be sounding like an 8 year old jalopy. The car has never towed anything, has never been overloaded, and has never been off-roading (although I have driven it on some dirt roads). Basically it has been babied, but has still developed this creak.
Any thoughts/suggestions on this would be greatly appreciated.
