Hey guys so I'm having an issue with my 2012 Outback 3.6 not starting. Battery is good, starter is good, alternator is newish, grounds checked, and fuses checked.
Finally checked for codes and I've got:
-P0700 (Transmission Control System)
-P0817 (Starter disable circuit)
-P0705 (Transmission range sensor circuit malfunction)
Symptoms:
-Car does not click or try to turn over, simply chimes and does nothing when attempting to start.
-Even though I'm not pressing on the brake, I'm able to switch between gears without holding in the brake. This is not normal and seems likely related to the issue.
-Car will not start in any gear including neutral
Any help or insight for this issue would be appreciated.
Symptoms:
