I noticed that the trunk hatch had two points that were flaking off at the same areas on either sides of the trunk thru the thread from Shep. I checked my 2012 outback and found out the same problem. So I'd like to share with you. See attached image and check your car if you are an owner of 2012 model. I set up the appointment with dealer and contacted to SOA.
