21 - 34 of 34 Posts
2011 2.5 Limited Cypress Green
Solution: Get rid of the crappy factory tires and your new set will come with lifetime free balance and rotation.
2004 Outback Wagon, 2.5, 4EAT, All weather package.
In the case of a vehicle that comes in with something not working, that is correct. But in the case of coming in with a fully functional system, they can't do anything that would cause the vehicle to leave with the system not fully functional. At least based on how I'm reading the legislation, if your TPMS is working when you come in and work is done that would cause any need to reprogram the sensors they would need to reprogram them before you take the car back. How would a tire shop know whether a TPMS is working or not considering how long it takes for the light to light up, I don't know.
Yes, that is correct.
I would assume the TPMS is working on your 2013, which is why I felt no need to mention it.
Every vehicle's TPMS is different. Most cars the light will come on immediately when a fault is detected. The vehicle cannot leave the shop with the TPMS illuminated if it came in without the light on. However if the vehicle came in with the light on because of a flat tire, we would check for faults in the system and make sure the light is out before it leaves.
Fact:
And yet our nanny USDOT/NHTSA is ‘so smart’ to mandate across the nation on how it is applied. Unless manufacturers can devise TPMS that is identical on all cars, there will always be exceptions/loopholes. kpk02 cites a fine example, the shop was in violation since they delivered the car with TPMS malfunctioning (but what else could they do).<O:p</O:p
<O:p</O:p
If the TPMS light remains lit I consider myself warned, but no I need Gov/someone to be responsible. I don’t want the temp gauge, let me have the idiot light (if I can remember between the blue/red indicator). There is no cure for stupid.<O:p</O:p
Fact:
<O:p</O:p
TPMS - is the result of too many people driving around with under inflated or flat tires till the tire explodes and they end up in a ditch because they were doing 75mph down the highway in a mini van full of kids. Run Flats were a major contributor to this.
I view TPMS like I do all the other fancy crap that has nothing to do with a car thats maintained and used correctly getting you from point A to Point B. In cases where you have shops that don't have the right tech to set up new TPMS sensors as long as they warn the vehicle operator and its in writing they can't be held responsible. However there will no doubt be Stupid people who go back an try to blame someone else for their stupidity at some point.
Which case you may find some shops choosing not to service your tires if reprogramming of "NEW" sensors is needed.
If TPMS was such a high liability then we would have some major problems with cars leaving shops with incomplete repairs - being driven around with engine lights on etc which pose a much higher risk to people than a tire pressure indicator light on the dash.
I put TPMS right up there with Nitrogen filled tires there are enough people out there that think "Nitrogen" filled tires indicated on their shop receipt is mandatory to a working functional vehicle. LOL - when if they hadn't flunked HS Science they would know that everyone's tires are nearly full of Nitrogen to start with.
Not quite, as it fails 49-USC-30122-(b) as it is intended to address (not withstanding the shop’s lawyer accepting that as policy).
The shop (legally) should’ve, from a posted/typ scenario… a.) Refused service as you stated, b.) Threw the winter set in the back or c.) Used/transferred the oem TPMS sensors to the winter set.
<O:p</O:p
What’s constant to the law is the car came in with TPMS ‘fully functioning’, it can only be released in the same condition – that’s why the law. My point to the whole mandate again, TPMS' don’t have identical stds to make implementation 100% practical.<O:p</O:p
What’s even funnier, if you had the shop mount a repaired flat (w/o ‘reprogramming’ FWIW), the TPMS would remain lit until 2 miles down the road. So they would’ve delivered the car malfunctioning, failing the TPMS regulation.
Again, stupid law.<O:p</O:p
Prime example of a law that will not ever be enforced at the tire end of the program.
The only time such thing will be enforced is during vehicle inspections as part of the registration process. Same applies to the engine error code light.
14 ob limited
No this is the funniest part of our government rulings:
The NHTSA essentially admitted in the 2005 Final Rule that they did not have the legal authority to force car owners to buy replacement sensors or extra sensors for replacement wheels. But what they can do is make businesses responsible for forcing car owners to do so by fining them $10,000 if they're not willing to stand in as the bad guys. Given that we've spent the past 6 years dealing with the monstrous kludge that is TPMS in the first place, it just seems like a huge slap in the face.
Thank big brother for this one!
When you are getting winter tires mounted on new wheels, just have them mount the tires, and put them on yourself!
And you wonder why small businesses go out of business!<!--/gc-->
2019 Jeep Rubicon Unlimited
I find this a little bit offensive. Unless you go to Donnie's Discount Retreads, I'm sure wherever you go will be able to reset the TPMS...
Maybe that was true years ago, but TPMS has been mandated on all vehicles for 5 years now... most shops have the proper equipment.
Also I'm sure Walmart uses a torque wrench, too much liability if they don't.
Not sure what part offended you, but the local tire chains (Discount Tire, for example) do not have the tools to reset the TPMS monitors. Neither did the local Firestone, Action Gator, or Sears. The dealership does. I wasn't out to offend, just to inform. Discount tire can move the TPMS from tire to tire, or rebuild the kit, but the ones local to me can not reprogram a Subaru ECU to accept a different sensor than the 4 already programmed in. In locations with cold weather (winter tires) and lots of Subarus (not Florida) that may be different.
If you are offended by the term tire monkey, then I'm sorry. Feel free to ignore the slang term and use tire tech or mechanic instead. No offense intended to anyone that changes tire for a living. Unless they are a monkey. In which case they are stealing jobs from humans, and should be beaten vigorously with a banana branch. In any case, please accept my apology if I offended, as that was not my intention.
I've had plenty of tires changed over the years... and torque wrenches are in every tire shop. They are usually sparkly, shiny, and mostly in like new condition. Unlike the socket on the air gun. Walmarts might be better.
I know the mechanic I take my car to torques them to spec, I know this because I'm usually 15 feet away, having a conversation with them. Make friends with the people that take of the things you care about, and you'll find your things are taken better care of. And who couldn't use another friend or two, anyways?
I'm not sure about 2013 Subarus as I don't think we have serviced one yet, but I know that there are very few vehicles that we have been unable to service TPMS sensors on. Our scanner works on just about everything and receives regular updates. At one point we had problems with Hyundai and Kia products, an update to our scanner's firmware remedied that. Most shops here in Western PA that change many tires have a similar scanner.
I only found "tire monkey" offensive because I work with a lot of good people who change tires for a living and bust their hump day in and day out. Go change a set of six 225/70R19.5 steel sidewall tires and then tell me how you feel :p. It is by no means an easy job, it requires a lot more strength and a lot more know how than most people realize. Especially in the winter when after you do the first car you are soaked and chilled to the bone from melting snow, you can't feel your hands, and your day is just getting started, and there is already a 4+ hour wait for customers the line is so long.
Torque is checked on every vehicle that leaves our shop, twice. This is a standard set in place by the TIA. I would like to think most shops follow TIA standards. All of our Tire Techs are certified through the TIA.
I do NOT change tires for a living. I was in retail sales until very recently, I currently am working on a digital marketing project for our business partner. When I was in sales I had to understand everything in a way that I could communicate to the customer and it would make sense... torque, tire pressure, TPMS, tread depths, vehicle systems, brakes, wheels... etc. It was the techs job to figure out the problem, it was my job to explain it to a customer in a way they could understand. This is why I also had to be TIA certified. I've also been through Goodyear Tire & Service Boot Camp.
Last yr was in DiscountTire for a winter set for my Accord and had them mounted/installed. With my car raised I approached the service writer and, “I take it you don’t use torque wrenches”. He then hurried out and next thing the tech appeared with a torque wrench with me watching through the window. U-huh, made me feel special. This is different than in an Ind custom wheel shop, even had the torque specs on the order.<O:p</O:p
TIA stds isn’t the problem, it’s the shop that makes/breaks it.<O:p</O:p
<O:p</O:p
On tangent, it appears the 2013 still has the 2010-12 TPMS programming by ‘dealer only’. On a NA Sym-AWD vehicle that can only accept 1 set of TPMS IDs, scratching my head on that one.<O:p</O:p
2011 Outback Limited 2.5i (sold 257,000km)/2018 Crosstrek limited 2022 Forester Limited
Hi.
Wal Mart charges 7 bucks per rotation per tire here for cars with TPMS, and 2 bucks for cars without it.
I dont really care if my sensor lights up, I am more than capable of checking my tire pressure by myself like a big boy (some modern features are great but does anyone in human civilization appreciate this stupid feature?)
Is this the only consequence of ignoring the tpms on tire rotations? i want to save the 20 dollar difference.
:2cents: If you know how to use a tire pressure tire gauge..which anyone should, you don't need TPMS. The added hassle it creates is just not worth it. If you have snows on separate rims then don' even go there. Just as easy to check manually.
When did we suddenly become so dependent on all these automated systems?
Back in the old days...when I had to walk 10 miles...uphill both ways...to school...lol....:29:
And why did we become so dependent on those damned pneumatic tires?
...baahh, humbug!
Looby
Thanks guys.
I just called firestone and they want 25 bucks for a tire rotation, so I guess it doesn't matter in the end. I'm not beating that.
I'll be buying the equipment and doing it myself next time.
THanks.
Go to Discount Tire if you have one in your city and will do the rotation and balance for ea tire for a one time price and then you get free rotations/balances as long as you own the car.
21 - 34 of 34 Posts
